starting my 998 fe- brrrrrrr!!!
tazmanxxx
hi. having a problem getting starting in this lovely weather.
getting turnover but nae kick intae life though. jist wondering if it might be the cold as it's in an unheated garage (so av jist bought an electric blanket tae try and ward aff the cold) will hae a look at the sparks- gonnae dae that the mora if am no to hungover that is. any feed back welcome.
p.s have had the battery on the charger so it cannae be that. cheers
I wouldn't depend on it not being the battery. You can charge it for as long as you like but if it has too much internal resistance it just won't put out the current to start the bike. At this time of year the oil is thicker so the starter has to work harder to turn the engine over. The extra current required can drop the voltage enough that you don't get adequate sparks. I'm not sure what ECU is fitted to your bike but the IAW5.9M won't work if the voltage drops below 10.5V, which it might well do while cranking. So first try it with a known good battery. If it still doesn't start then look elsewhere. Check all the connections from the battery to the solenoid, from the solenoid to the starter, from the battery to the frame earth and from the frame to the engine earth. The battery terminals are crimped onto the battery cables. It is not unknown for the weather to get into the crimps, causing the wire to oxidise resulting in resistance and bad connections.
If all that is ok - are the plugs in good order with the correct gaps? Are the valve clearances within spec? Is the TPS set up properly?
