starting issues
jim@southwales
hi ,bought this s4 (916 engine )about a month ago ,
on trying to start does so sluggishly that's if it turns over rather than going humf turn key humf turn key turns and starts
today on trying to start had a backfire through pipes prob me try to adjust the manual choke :comp2:
gonna replace battery but is there any other factors to look out for
all my previos duc's started on the button
once running- like a dream
any advice welcome
Batteries are such an essential and hard working component that I think you are already on the right line suspecting a tired battery...
But it might not be the whole story if the battery is not getting a good charge from the bike e.g. failing rectifier/regulator or poor generator output.
I added an extra power feed cable to the starter motor and it did help a little, likewise ensuring all the earths (some are often hidden) are good can be necessary.
Good luck - Frank
NB - being a good DuN member you can also ask for battery discount here:
http://www.mdsbattery.co.uk/departm...entName=Motorcycle+Batteries&DepartmentID=155
