ducatifosi
Hi all, after getting the ss running this summer after many years of embarrassing neglect she was running ok but, idling poorly.
This winter I have cleaned up the carbs/jets,fitted new seals and needle valves(tdm850 has the same carbs with parts at half the price).
Upon reinstallation I have hit a problem.
Refitted carbs,breather pipes,batterybox,battery(reading 13v),coils and Cdi units(reading 105ohms).All connectors seem correctly fitted(have used microfiche diagrams and manual for reference aswell as photos.
Upon key turn I have dash lights and fuel pump whir but,as I hit the starter button there is no click and the pump whir decreases in volume. I've looked around on many a forum and post and am guessing it's my starter solenoid/relay(was working fine this summer but, did have problem before its long layoff)When I cross the terminals I get a starter noise so am assuming the starter is ok.
I've double checked the battery leads,cleaned all the terminals and relays, fuses are good I've cleaned/checked the starter/kill switch and sprayed it with gt85.
Am I missing something obvious? Or is the solenoid where I start.
Any input is greatly appreciated however simple it appears. Really thought I'd get it going today but, my ss always make me work for its pleasures
Regards
Steve.
Regards
Steve.
