starter motors help
gordj65
help my starter seems to have jammed, ive tried the usual stuff, rocking it,hitting it etc,does anyone have a spare for an st2 i would imagine theyre the same as 900ss,are they the same across the whole range, can they be stripped and regreased and put back in and finally how do you remove them from the block i can only see one bolt i take it there are others...........any help greatfully accepted:dunno: :confused:
thanks for that derek. i was kinda hopeing it was going to be a three bolts and out job, but kind of new it wouldnt be. i couldnt be that lucky. i take it im going to need a flywheel extractor tool?looks like ill be in the garage for a few evenings, that will keep the wife really happy.had to send her a pic today so she knows what i look like ;)
You'll need something to lock the flywheel when you undo/tighten the nut. I'm told that a copper coin (2p?) wedged in the gear teeth does the trick. Either that or pay a load of cash for the Ducati special tool.
I remember George at Ducati Glasgow saying they were all the same across the range up to around 2000.
Everyone says this, but is it definitely the motor? Have you tried arcing the terminals on the solenoid to see if there's any movement in the motor?
If it is knacked you can get one from Bikenders for around £50.
i managed to get the motor body off without stripping the casing etc with the aid of a 8mm spanner bent to suit the angle i needed and oh deary me what a sorry state its in. brushes were down to the wire windings were wearing the new flush look,apparantley de riguer for all knacked starter motors, and the magnets were as follows one broken in two, two loose and moving around and one still in place.
it is safe to say that it has turned over for the last time.now its time to get a replacement and fit it. bloody annoying as id only serviced the bike 500 miles ago and now its dump the oil time. it makes my poor we wallet bleed
tried bikenders spoke to jim and arranged a very reasonable £68 for a 3000 mile one,so im well happy with that one cheers for that tip;)
Starter motor
I may need a new starter, who are Bikenders,contact ect.
You can replace starter brushes ( got mine on ebay £28) ducati spares online.
Removing crancase cover is a right pain.
SEACAP
i managed to put the new starter motor in without having to mess about with the flywheel at all im glad to say dont know if thats just st2`s maybe.i did find i had to undo the coolant hoses and drain it all off as couldnt get the side casing off with them on .was already at the point of putting casing back on when i realised i hadnt any sealant so i stopped at that point.
should have said i had to make up a wee puller for taking the casing off as its a tight fit thats needs to be pulled off evenly. but that apart so far so good:thumbs:
