Explaining shear stength is a bit like explaining the offside rule in football but I'll have a go.
Tensile strength is basically how long a material will stretch before it fails. Compressive strength is similar but failure always occurs by buckling before material yield. Pull a piece of paper between your hands and it straightens, push a piece and it buckles. That's why all engineers try and design frames to be in tension as much as possible under all load conditions (cars, motorbikes, buildings, aeroplanes and bridges) Now shear is a different animal alltogether and is difficult to explain without a practicable example. Shear failure is primarily why the Twin Towers collapsed and it subsequently induced a buckling/compression failure in the lower storey columns. Here goes, shear failure is caused by two opposing forces acting in the same plane at the same support. 'At the same support' is crucial here as in braking terms this is where your calipers mount to the forks and where your discs mount to the wheel. The bolts will snap across the thread and bolt shank and not by pulling. ie. Shear stresses are generally perpendicular to tensile/compressive forces. I don't think I've explained this well, probably the red wine) but I could easily show you with a pencil and ruler. The reason why stainless isn't used much in aircraft engineering and maritime engineering is because it's unpredictable in shear and results in immediate failure without warning. I would never use stainless steel on my bike, but I would use titanium.
Where's Louise when you need her ?
Winston, can't believe you stopped halfway through a bottle of red to answer Davie!![]()
Yeah, he will be well baffled now!
I don't know, I thinK he'll understand the stockings and suspenders bit !
I'll read this in the morning......
2moro's Saturday mate
There is a chemical reaction when SS and aluminium come in contact with each other,I use to work with a lot of SS components and always had to fit nylon washers or spacers to separate parts but if it's a press fit can't see it being a problem,as air can't get at the contact surfaces to create oxidisation and, I can't see a stress problem either,anybody with more info?
There is also a chemical reaction when ammonia is in contact with SS which causes the stainless to become brittle.
