ST4S wheel bearing spacer
ratchet
Just replaced front wheel bearings, spacer between them was originally quite slack and had a mm or less of clearance but could be moved freely between bearings, but just fitted a couple of Timken 6005 2RS C3 bearings as better quality than SKF, but on "bottoming out" second bearing, spacer is now solid between bearings, and only rotates with bearings.
Is this they way it should have been from the factory? Or I have I inserted too far........
That's the way it should be, so that the torque when you tighten the axle nut is across the spacer and both the bearing inners. An axial load on the bearing rotating parts would cause them to quickly wear out as well as create extra drag.
:confused:
Now fully fitted, have dull intermittent rubbing when spinning wheel, like spacer webs catching inside wheel, that's 3/3 jobs that have not gone to plan:mad:
Gonna run and see if it wears off, hopefully!
