ST4s suspension settings
900triple
Hi all,
Just wondering if anyone had recomended front/rear suspension settings for a ST4s? I'm 110kg
Alan
When I had my ST4S I paid to have the suspension set up for me by a local (to me) specialists. The one mod that they did do was to drop bike 10mm on the forks . When they finished it cornered like it was on rails.
I dropped the forks through too. Could only get it to handle by winding the rear preload right up (the tip i read about was to put it on the centre stand and wind it until the rear tyre is just in contact with the floor), but then the bike was too tall for me so I couldn't live with it.
Gave up in the end and sold it. Just wouldn't turn in. Couldn't get to grips with it at all.
Glad i never sold the Monster S4, because that handles brilliantly.
EDIT: In fact, just realised it was you who bought it! The forks have already been dropped as far as they'll go.
yes don't be shy, wire into the rear ride height rod (not left hand threaded nut has cut out on it's corner, maybe) and get the back end right up in the air, then drop the front end.
ps. the st4s frame is the same as the monster S4 frame, but the st4s has a short wheelbase because it can because of the extra weight of the fairing over the front end, just ride the st4s as if it was monster, just throw it about and see.
in for a penny in for a pound, i run 36 / 42 tyre pressures on diablo corsa's, as i did with my fireblade and vfr, it's not hot enough here and roads are not smooth enough for the lower tyre pressures imho, so dismiss the ducati are sensitive to tyre pressure myth, it's just another motorbike and it should be treated as such.
Had a smile when I was reading your post Paul...wondered when you'd twig. I'm 6'1" so increasing the rear end shouldn't be a problem. I'll try it at the weekend. Cheers.
Haha!
Just treated the Monster to an öhlins rear shock and Traxxion Dynamics front spring and piston kit. It's insanely good, and the roads are still greasy.
It defintely responds much better with that rear preload wound up as I mentioned.
