ST4s seat lock
853RS
I have a friend of mines ST4s in for a service and he said the seat lock is not working and cant get the seat off.Turning the key and nothing is happening.After having a good look at the back of the bike how do you get in there,looks impossible.The panel that covers the seat lock is at the back of the tail light,the bolts for the tail light are under the seat.The
seat cover was torn at the back so I managed to get a look at the at the other side of the seat lock.So drilled out the 2 seat lock countersunk screws from the back with a 4mm drill and managed to get the seat off .Once I got the locking mechanism out discovered the adjuster on the seat lock cable had slackened off and the cable nipple had come out its slot.Refitted the cable and adjusted and bent over the cable guide so it cant come out and do the same again.
Will do the same mod to my bike just in case.:)
Alex, if the cable comes off it's possible to get a long slim screwdriver under the edge of the seat and push the lever across to release the seat. But prevention is the best answer.
