ST4s rear wheel bearing replacement
iconic944ss
Finally decided to change the rear tyre on my 4s after the Highland fling adventure.
Wheel out, quick feel of the bearings to check all is ok - Oh dear...
Both carrier bearing are rough, as is one of the wheel bearings so, full change.
Tried my new super-duper internal bearing puller and blow me if it didnt annoy more than anything else, biggest puller was too big, next size down (which was meant to have overlap), wasnt big enough :mad:
So back to my usual cack handed method of bearing removal.
Dig out the middle seal, puncture the holding cage, vent anger by ripping the cage in various bits, tap / hammer the balls together, tap / hammer the inner race so it and the balls can be removed...
Looks like the original bearings the bike was fitted with! No damage to the spacer tube at all. Opposite bearing removed via time honoured socket and long extension and the first outer race removed sweetly by using a 32mm socket that is a really nice fit.
So I have two undamaged bearings (as the sprocket carrier bearings were easy to remove) to help with refitting - I'm guessing freezer overnight and warming the wheel and carrier are ways to go...
All help appreciated!
Off the get the bearings from a stockist now - expense of late - good job its a new month ;)
Why all the drama Frank? :D
There is a notch in one end of the bearing spacer that allows you to get a long drift into it so that you can get the adjacent bearing knocked out from behind. Once that's out the rest is easy. :p ;)
Lol, I'd love to know how long a drift! Mine is 8" ;) and wasn't long enough!!! Spacer tube was tight on the bearing too.
No install suggestions ???
I used a length of 1/4" rod about 10"- 12"long with the end ground to allow it to fit into the notch in spacer.
Use a socket that has a diameter about the same as the outer of the bearing so that it only bears on the outer ring when drifting the bearing in.
I had to do them twice on the ST4s. The first time I changed the bearings I bought them from an internet shop called bikebearings. I should have known better, I had to replace them after 5,000 miles. :rolleyes:
Cheers Derek.
Local bearing stockist, FAG bearings, all four, cash only sale and he waived the VAT as well - £25 :D
Hopefully, these will last 30,000 miles too!
I should also have mentioned, it helps if you put the bearings in the freezer for an hour or 2 before fitting.
Job done - bearings in freezer overnight, wheel and sprocket carrier both heated gently to get best results.
Biggest bearings in the carrier, were the easiest - worked fine using an undamaged old bearing.
The wheel bearings also appeared to go in fine but despite only gentle hammering they felt tight and the spacer tube would not rotate without the inner races turning.
So I finally made a long drift and very gently tapped the bearing out over to try and introduce a very little bit of play. Seemed to work and once assembled the wheel turns a treat.
Time for a brief rideout ;)
The inner spacer should be a tight between the inner races. When the axle nut is torqued up the load is taken across the bearing inners and the spacer. There should be no axial load on the races or you'll be replacing them again very soon.
