any one done the swingarm bearings on a st2 before,any tips or advice would be more than helpfull,before i bring out the hammer and chisel and attempt removal in the good old fashioned way,dont want to hurt ma wee babe lol
I've never done the swinging arm bearings but there are a couple of things to look out for. Watch out for any shims between the swinging arm and the crankcase. They are there to take up any endfloat and you'd want to put them back in the same place as the came from.
At each side there are two needle bearings (SKF HK 2016), a seal behind them and a seal on the outside, all located against a snap ring ( see the pic below). The manual says nothing about how to remove them but if you are knocking them out from the opposite side that snap ring is going to get in the way.
