ST2 revcounter over reading ??
muxey
ST2 revcounter over reading ?? At around 4k rpm its reading aroun 10k
any one have any ideas ?:confused:
when the bikes reading 10k on the rev counter does the engine sound like its revving at 10k??...could be your clutch slipping
if not then its an electrical gremling..take out the block connectors behind the clocks and make sure all ok..squirt with some electrical contact spray...then trace the loom back and check that all other connectors are ok too
I had a problem with mine which was inoperative from a cold start and then got going after a few miles. Checked all the wiring which was ok, but ended up buying a new one from E Bay Germany. If you live local you are welcome to try my old one?
Had same prob on the old ST2, this was after jumping it from the car cos the battery was fooked.....thought to myself that I had caused a prob, but new battery on and it sorted itself out back to normal in a jiffy! May not help you if your battery is good but thats me 10 bob's worth...
