ST2 Nuetral Light Fault
:(Dont know if anyone else has had this problem but my ST2 has developed an annoying fault whereby the neutral light stays on even when in gear,and changing through the gears. If anyone knows of a cure please contact me.
Thanks.:lol2:
Dont know about ST2's but I assume the sender will be of similar design to mine
Check the switch operation/plunger or see if it has come slack in the casing
Hi Robert, my 996 did this once after washing it, sprayed the switch with wd40 at the back of the crancase IIRC and was OK thereafter.
my monster used to do that all the time..... light on when you're in gear and light off when you're in neutral ...and not consistenly either so you were never really sure new where you were :rolleyes:
Now the light doesn't come on at all and it makes life sooooo much easier ;) :D
I must admit I never look at the light any more - the only way I get neutral is to knock the engine off & roll the bike. It's either that or spend the rest of my life Klunking between 1st & 2nd
