ST2 Clutch Grumble
BruceCampbell
Been out on the old ST this pm and there seems to be a problem with the clutch, when setting away from standstill the clutch makes what I can only describe as a groaning/grumbling kind of noise...THe clutch is still fully operational and it is just over a year since the bike was with Ducati John for a full service including clutch strip/inspection....It may be nowt but anyone got any ideas??
have always find mine does this when very hot and only at very low speeds. ie taking off or trundling along in traffic. not caused me any real problems so far
my 996 did it on occassion. I think it's the plates sticking together, then seperating that causes it. quite common.
Common problem and easy to sort. Just take all the metal and friction plates out of the clutch basket. Note the order of metal plates, in particular look for any with a dot punched on them (the dot plate must go back in the same position.
Fast - give all the plates an order shuffle and replace.
Slow - use a scotch brite drill attachment to remove all the blueing on the metal plates, shuffle and replace.
The graunching is caused by the build up of cr@p from the friction plates.
You can always fit an open clutch cover or do as I have, and fit a couple of washers between the clutch cover and the engine casing, thus creating a couple of millimetres gap for the cr@p to escape.
St Grumble
Thanks to you all, will sort over next few days, in the mean time its time to fire the 748 up and put on the one piece suit!!!!
As a newbie this is my first tech query and the response has been spot on!!!!
cheers
