SS Cylinder heads
sam
I have read that the letter V stamped on SS cylinder heads is the larger valve dia compared to the W anyone know what Y4 stands for ?
V2 is the normal. W is the ones with smaller valves fitted to some Monsters. Don't know what Y4 is :confused:
The only changes I can find was that from 1997 they manufactured the heads with sintered steel valve seats. With the 750 only being 4mph slower than the 900 I take it it had the larger valves as well.
From Brad Black :-
The not so good carb engine came in 900 Monster from engine number 037728 and the Cagiva Elefant series. The differences are camshafts and valves. These lower spec engines have 750 cams and valves. The valves are a couple of mm smaller. The cams are a little wacky, being about the same duration, but lower lift than the good 900 cams, with different timing, much wider lobe separation and less overlap. To my mind, they are an old cam design, borne out by the part number beginning with 0370, indicating something from the early or mid eighties.​
This implies that the 750 has smaller valves and a lesser cam. I don't have a parts list for the 750 so I can't say which bits are different from the 900.
From Brad Black :-
2000 model 750 motor had part nos. 211.1.015.2A and 210.1.015.2A for exhaust and inlet.
Any use or were FI motors different anyway? (2000 900 motor had different parts numbers from 750 as well)
Sorry 2000 900 parts were 211.1.003.4A and 210.1.003.5A respectively.
Did the F1 not have the rear head pointing in the correct direction with carb to the rear?
Might not prove much Stewart. The exhaust valve for the carb 900 is 210.1.003.4A (the same) but the inlet is 211.1.003.4A ( the different suffix most likely, but not necessarily, means a detail change such as the material it's made from). Although I'm 99% certain the 750 had smaller valves.
Here's the answer to the cams.
CAM .I.O. .I.C. E.O ..E.C. IN DUR EX DUR IN C/L EX C/L IN LIFT EX LIFT
750 ..12 ...70 ..56 ...25 ....262 .....261 .....119 ..105.5 ...9.35 .....8.5
900 ..24 ...70 ..58 ...29 ....274 .....267 .....113 ..104.5 ..11.75 ...10.56
And as far a I can tell, the 750 and 600 have the same heads.
All info from Brad Black
Yes the F1 had the same configuration as the Pantah with exhaust exiting at the front and carb at rear.
However I was referring to fuel injected (should maybe have said IE instead of FI) and just trying to confuse you...and me! Sorry!
