Spindle clamp has cracked
posiden
Well-known member
Just fitted some new tyres on the bike today and when I tightened up the spindle clamp bolts on the right hand leg the material surrounding the bolt snapped off the fork!!!!!!!!
Its a 2009 Streetfighter S with Ohlins forks.
Needless to say im absolutely gutted.
Does anyone know if its fixable.
Would it be covered under warranty?
Is the bike safe to use as it is?
Sorry to hear of your problem. My 2 pence worth:
1. Everything is fixable but would you trust it?
2. I would doubt it, unless you could prove inherent fault
3. NO
The bolts should be torqued to only 19Nm. You will need a new fork bottom but these are not listed as separate part, in fact the only fork bits listed by Ducati for the Streetfighter are seal kits. I would imagine that you will need to send the fork leg to an Öhlins service centre for repair.
best speak to Harris Perfomance (UK Ohlins Importer) for a replacement fork bottom, K-Tech would also be able to sort you out, although admitedly they are focussing less on Ohlins these days and more on their own range but still know the Ohlins stuff inside out.
There was a recall on 1098/SF righthand Ohlins fork legs last year -surprised you have not had a recall letter or contacted by your dealer if yours was included, best check if its due
Oh fork
cheers for the replies chaps.
I had a very quick and informative response from Ohlins today.
the e mail read:-
"The forks should be taken to your nearest official Ohlins Centre where they will replace the fork bottoms under warranty. This has been an issue where we've found the pinch bolts can be over tightened, which causes too much stress around the spindle. We have since redesigned the fork bottoms to accommodate the risk of over tightening the pinch bolts."
Full marks to Ohlins for repairing under warranty but I do have to ask, if this bike was over two years old, would they have done it and
why the hell have Ducati not told me about it considering it goes back to August 2009 (as per the link - thank you very much for posting that.)
If i hadnt noticed it last night I would have quite happily been riding round on a bike with the potential for the front wheel to fall off !!!!!
Come on Ducati surely you can do better than this.
I will post some photos later but the design flaw is pretty obvious when you see the broken part.
Ive attached three pictures of the broken fork lower.
If you look at the second and third pictures and you take into account that the bolts are 8 mm and the holes are 9mm in diameter you can see there is not a lot of material left after machining to actually do the load bearing part its there for.
View attachment 6168View attachment 6169View attachment 6170
Their well FORKED.:eek: You should be asking the local Ducati Dealer you bought the bike why you had not recieved a re-call notice. Normally Ducati are pretty good with these.
the e mail read:-
Where do you have your bike serviced? all Ducati dealers should check for outstanding recalls at service time and is your bike registered to you on Ducati,s system?
we used to see exactly the same fault on certain mountain bike forks, TBH its probably not that the forks are incorrectly designed its just that they are incorrectly designed for the anyone who dont know what that clamp actually does and tightens it up too far thinking its "more secure".
The axle is held in the lower by the big f'ck off axle bolt, all that clamp does is take up a tolerance which is needed to allow the axle to slide in, as Derek says its a really low torque and over tightening puts you at more risk than under tightening.
I've always been surprised they didnt put a rubber spacer in to prevent over tightening especially when you start pushing weight boundaries. This is the problem MTB forks suffered from, a desire to go lighter, lighter, lighter then you see failures as users dont understand them then fork lower ends up getting revised to allow for that after the things start failing :D
Update
Well I have got the bike fixed by the very nice people at KAIS Suspension in Manchester whom i can thank enough for getting me back on the road.
The official line from Ohlins is this:-
"Apologies if this situation has been anything but straight forward, but it seems the warranty on these fork bottoms is also far from straight forward.
I'm not familiar with what's happened in the USA I'm afraid and I don't want to comment on people's feedback from a forum, because Forum threads are very rarely accurate. However, I can say that Ohlins Sweden has never issued a recall on its forks for Ducati.
The situation in terms of warranty is thus:
If a crack has been found on the fork bottoms near the brake caliper mounting, the fork bottom will be replaced under warranty for a newer design.
If the fork bottom has a crack near the spindle, this is normally due to over tightening of the bolts. The spindle used by Ducati is very thin and if the securing bolts are over tightened then this can cause deformation of the spindle and therefore lead to crack propagation in the fork bottom. Ohlins has informed Ducati of this situation, but we do not feel this is a problem attributed to the forks, but that of the spindle. Of course if we should supply all Ducati owners with new fork bottoms under warranty, there is nothing to say the bottoms won't crack again due to over tightening of the fork bottom, which is why we don't replace these under warranty in this situation.
Apologies if I've misled you into thinking these would be automatically changed under warranty, now that I have all the information available to me I can see that a replacement under warranty is specific to a certain area of the fork bottom, which unfortunately in this case does not apply."
Ohlins and KAIS have been good over this missunderstanding and at least Im back on the road and not really badly out of pocket considering it could have been a very expensive repair.
The bottom line is this:-
19nm is all the torque required to nip the spindle.
Make your tyre fitter aware of the torque setting when he reinstalls your wheel.
KAIS also set up my suspension while I was in and the bikes handling has been transformed. Worthwhile doing if your in the area.
