Spark or not to spark . . . . !
Silver-Surfer
OK
Bike broke down last week on the way to the DOC evening meet !
Got very wet in the morning on the way to work and I think I got water somewhere it shouldnt have been ! Bike started ok in garage at work but as I went down Bath Street it was playing up, sort of miss firing. I thought I know I'll go a quick blast down the M8 to wam it up and dry up what ever was the problem. Big mistake, should have head to the meeting. Got as far as Junction 23 and had to come off the M8. Bike wouldnt rev and eventually died !
Got recoved home and didnt make the meeting.
This has happen before when I have washed the bike but it usually drys out after a few days, not in this case.
The bike turns over no problem and I get fuel but no spare ! I have changed one of the ignition modules and still no spare.
Ideas please ?
Wont make sunday unless I get it fixed :)
Ah life with a 16 year 748 !
SS
Ideas please ?
Aye sell it. Track it
Or get a 998s
The best value ducati (sportsbike)for brick
If you can find one
Good luck
This post should really be in the Technical section and although I have the power to move it I'm not sure how to, so best leave it to Miles as I don't want to end up deleting the post altogether :o
If the fuel pump primes when the ignition is turned on you will definitely have power to the coils as well as the pump, so the problem is most likely on the HT side and more than likely with the front cylinder as that gets all the water thrown at it from the front wheel. Remove the plug lead and check for water in the plug recess. It might be an idea to change the plug lead for a new one anyway, and the plugs while you are at it unless they are fairly recent. Refit the plug lead with plenty of silicone grease or vaseline to help keep water out.
Cheers Derek
Took the lead off and use a spark testers thing to see if I could get a spark but nothing ? will change the leads.
If not will drop a match in the tank !
SS
If the pump is priming and there are no sparks at either cylinder then it is ECU related. Crank sensor possibly.
Derek
You are da man again !
Its th ECU and water ingress ! Took the round rubber plug off and the inside of the ECU board is furred up ! The bike aint going anywhere till I get a new one FECK !
Funny thing it that the ECU say Ducati 916 Bipoto on the bottom and its a 748 ! Me thinks its not original !
Oh well e-bay here I come unless anyone has a spare I can try to make sure it is th problem !
Cheers again Derek
Duncan
There is a good chance it will come to life again once it completely dries out. If it does, or if you end up with a replacement, cover the rubber bung with duct tape or pvc tape to keep the water out.
The 1.6M ECU fitted to a 916 is the same as that fitted it a 748. The difference is in the chip (EPROM) that is fitted.
Thaks Derek. It looks so furred up I dont think it will dry out. Some of the circuit board has sort of melted !Gona take it in to Ducati Glasgow so they can laugh at me and the ECU and tell me its dead.
Duncan
£96 for a secondhand ECU from EBay ! Changed the Chip and all ready to go !!!
Look out for me on the M80 going to Glasgow tomorrow !
Cheers guys
SS
