ian900ss
Ok, so a little update, I had posted about help with carbs but after much head scratching it appeared that it was an ignition problem.
Basically it ran but very badly, sounded like it was only running on one cylinder but when I twisted the throttle it struggled, would not rev and died. Basically it wasn't advancing the ignition with the attempted increase in revs.
So I got a suggestion it was the ignition and this was narrowed down to most likely being the pick up coils. If they weren't working it would give the problems above. So I changed them. No difference. Then I got another suggestion for switching the polarity of the pick up coils. I thought that they could be connected either way round, apparently not cause after swapping them round now its running sweet and revs beautifully! I had copied the original wiring when putting bike back together and the coils are not the original, they had been changed prior to me getting it. but it was a non runner when I got it too.
Lots of smoke coming out now so I am going to change oil and sparks and evaporate petrol in the chambers and try again. Then hopefully MOT!
Thought I would post this in case anyone has similar issues.
