Some first impressions and observations
CJK
Very sensitive to start....wee fast idle button in,fire her up and leave her for a few minutes....or she cuts out, overfuels(?),won't start, running the battery out.... rather quickly for my liking:eek:(new battery,I think current ones been a few years i'll check invoices).
14t front(one down ??)/36t rear sprockets,I've been up and down the street a few time and she's a lot easier to burl a round than the SS which was standard sprocket wise,I'm presuming the 1 tooth down on the front contributes to the better slow speeds.(gritters have been out around here the last 2 nights before anyone starts:finger:)
A lot more of bark from the termi's...(lowish 4k max/revs) than the growl from the bos cans on the ss.
Very lazy rev counter,doesn't move at idle...anything obvious i could check?
as you were,
grazie,Colin
ps Mr Tamburini,your a star :D
Your fast idle button is like your choke. If you touch the throttle after starting the button trips out and it will die if the engine is cold.
You should be able to just ride off though from cold.
Battery sounds on it's last legs as Derek says and these bikes need a healthy battery to turn them over quickly enough to fire.
Are you starting to panic again? :lol2:
Deep breath and relax!;):D
presume the rev counter is a giveaway?
Yes. First thing to stop working when the volts are low is the rev counter. If the regulator packs up the first indication that the volts are low is the rev counter stops working. In your case the battery volts are dropping after a cold start and it's taking a bit of revs to get enough charge to bring the voltage back up to a level that the rev counter likes.
