Anyone using one, I am looking at SOLAR POWERED 15 WATT BATTERY CHARGER for CLASSIC CARS 12 VOLT + | eBay
I wondered how much sun it would need
any recommendations
any recommendations
A damn sight more than you get on The Rock...Anyone using one, I am looking at SOLAR POWERED 15 WATT BATTERY CHARGER for CLASSIC CARS 12 VOLT + | eBay
any recommendations
Thanks I hadn’t thought of that, reet off to research charge controllersI've read the advert and you've zero protection against overcharge.
Flexible 150w 100w 120w 50w 30w PV Solar Panel for 12v or 24v Battery System UK Flexible 150w 100w 120w 50w 30w PV Solar Panel for 12v or 24v Battery System UK | eBay
Is a better solution, oversize the panel and use the charge controller to keep things sweet.
If you over charge the battery your minimum damage is a new battery and you know what the maximum damage would be!
Biggest panel you feel comfortable with £££ 20W is fine and one charge controller, (it includes a diode to prevent reverse heating of the solar panel in low light). that advert had both at reasonable money. Make sure the panel is IP56 or higher...Thanks I hadn’t thought of that, reet off to research charge controllers
