So got a few issues with my 749 .....
fab749
So i need some advice and recomendation for parts.
lso brake pads - rear - recomendations?
Chain and sprockets - size and models please
thanks ppl
Ive never experienced anything that you describe but "whining" covers a lot of things. What exactly do you mean?
In this instance i would say it is up and down the rev range a constant back ground whining/buzing sound. It is realy dificult to describe but it is basicaly all the time .. alters pitch with revs.
i have a .wav recording of it but not sure how to upload can anybody help - it's too hard to describe the sound..
its awav file and its too big ive tried to compres but stil 350 kb so is ther another way?
although not the best quality it gives a good representation of the "yowl" the wav file i have is better but cant work out to upload itr
sounds like bullets richocahing off something
and seriously bad not sure id run the engine again till i knew what it was
err, email us the wav and il host it somewhere or something
tatey80@hotmail.com
Have e-mailed it you thanks.
Sory having listed the above clip - ignore the initial noise as that isn't actualy present (ricocheting) its the sort of miaow you can hear behind as it were, thats the problem.
Are you sure someone hasnt swapped your engine overnight for an inline 4?
Doesnt sound right.
I wish perhaps i wouldnt be havng this problem!!
Ive changed the front bearing on the clutch spindle thing as that had a bit of play in it. that hasn't resolved it.
It has had new tensioners trying to eliminate and that hasn't cured it, i need to check with the garage whether they changed the water pump bearings. MOT garage said he thought it may b those.
Oh well at least it's coming up to winter..
thanks for posting that clip for me too scotty :)
Seeing as your in Leeds i'd pop it down to Ducati John by the Arla building on Wakey road. let him have a listen...
