Slipper clutch question ?
  • Thread starter Thread starter iang27
  • Start date Start date
I
iang27
Just visiting
Got my slipper clutch fitted and I have measured the gap between the end of the clutch hub and the back of the pressure plate and it is 1.5mm which is what is recommended by Bucci/Sigma/JHP etc. Also the gap from the last friction plate from the end of the clutch drum is 4.5mm which is also recommended.
When the bike is started the pressure plate spins as normal, when put into gear with the clutch in the pressure plate stops completely until the clutch is released, is this correct ?
I cannot remember my 749R pressure plates stopping completely, I seemed to think that it just turned slowly but never completely stopped.
Any others with slipper clutches noticed ?
I dont think you should be alarmed, my 748 does that. As far as I know its normal. That said, i've not got a slipper fitted!
Regards,
Wayne111
my 748 stops, i think its cos when in gear with bike still the gears mesh so clutch can't spin :)
the pressure plate gets pushed off the stack by the clutch push rod, once it leaves contact with the last steel plate and the pressure comes off the stack it can't turn as there is nothing driving it the only contact point is the pushrod and that doesn't spin and even if it did the pressure plate has a bearing so the rod spins in that. I can't recall if the tanged plates are connected to the engine and the steel plates to the gearbox but no doubt Derek will be along in a while to let me know :) but if it is that way round even if a steel plate did stay in contact it shouldn't "drive" the pressure plate.
slipper clutch
the red pressure plate will turn when in nuetral(no clutch lever pulled in) the 6 springs keep the pressure on the whole clutch drive plates and friction plates
pull clutch lever in to engage gear the push rod pushes the red pressure plate out compresing the 6 springs this releases the pressure on the drive plates and friction plates the red pressure plate will slowly stop
friction plates are conected/driven by outer clutch basket
drive plates by clutch center hub
release the clutch lever the red pressure plate moves back (forced back by the 6 compressed springs) and the pessure is back on the whole clutch asembley drive&friction plates and the red pressure plate will be spining round and a way you go in 1st gear
:) :comp2: :comp2: :comp2: :lol2:
The pressure plate locates into, and slides on, the clutch drum which is attached to the end of the gearbox input shaft.
When the bike is in neutral and the clutch released,the whole lot turns together.
When the bike is in neutral and the clutch is pulled in, the pressure may or may not turn depending on how much drag there is in the clutch.
When the bike is in gear and the clutch is pulled in the pressure plate will remain still as long as the bike is stationery because it is directly connected to the rear wheel via the gearbox and final drive.
I hope that answers the question.
Yes thanks for the input everyone, I just could not remember when it was on my 749R if it moved or not.
Was pulling my hair out yesterday, I had the clutch plates in and out about 6 times with different stack sizes but every time that I put the bike in gear it stalled, so out came the plates again, assuming that it was them causing the problem. It helped when I put the side stand back up !!!!
