Showa forks twiddly bit
pylwagl
Member
I have a '93 900SS with the adjustable Showa forks, which work fine except for a leaking seal which I'm about to replace. I've noticed that when the rebound adjusters (the brass screw on the top - pic) are set with equal amounts of clicks they have different amounts showing. They seem to work fine but it looks a bit odd / cant be correct to have one sticking up further than the other. What's going on? Is there something I can adjust/fiddle with while the forks are apart?
TIA
Stu
@WAYNE might have some experience if not an owners manual where it gives the factory settings
TIA
Stu
Probably the top assembly has been fitted at different lengths/ heights on the damper tube
difficult to explain without pictures
you can match them by measuring from top of outer tube to bottom of the rebound/ preload assembly and adjusting , make sure you have all 14 clicks tho it is possible to get more or less clicks
but really needs the factory measurement to be 100% correct
Or, fully turn both rebound adjusters anti clockiwise to the stop. Then, while they are off rhe forks wind them clockwise equal clicks. Screw them on the damper rod until the fork tops "bottoms" out on the damper rod then nip the lock nut up. Job jobbed.
TB
