Scottoiler fitting for 2000 on Monster
Steve748
Finding a place to fit a Scottoiler to my monster was proving a little difficult until I spotted a gap down the side of the headlamp mounting bracket on the RHS with a well placed mounting lug for a wiring connector.
1. Remove the connector and with a screwdriver push the plastic clip out and with a half round file remove some of the plastic to make a nice snug fit to the reservoir. Hold the reservoir in place as per photo and mark it through the hole and superglue the plastic lug to the reservoir. Then put a couple of cable ties round the lug/reservoir and glue them in position as photo. If the clips are in the right place they should be touching the headlamp shell providing a bit more stability. When it's dry fit reservoir and the clip should fit into the hole. For a bit more stability put another tie round the subframe of the lamp and the reservoir.
2. The breather is fitted and pushed through to behind the headlight.
3. Fit the M5 spigot and feed the black tubing through to the top of the reservoir
4. Fit the delivery end of the clear tubing to the bottom of the swinging arm with long cable ties so it is at 7 oclock and just touching the sprocket. Then feed the tubing along the hoop and through the frame to the reservoir. A cup of boiling water and some pliers help with fitting the tube to the brass fitting.
5. With a sharp blade cut the bottom corner off the flat plastic sticking out of the ajuster on the reservoir. This is so that it can be turned down without fouling the fork.
6. Turn to prime and go for a ride and after about 5 miles stop and turn the ajuster right down til you get about 2 drips a second.
This is about the only place to put it and is fairly unobtrusive and easy to fill and keep an eye on the level in this position:)
tail chop is a dirty word
interesting resevoir location though
Interesting to me means your not sure.................The only other place is on the frame. I have been thinking about it for a few weeks (not one to hurry things) and it looked really strange there by the headlight and I was not sure about it at all, but now I have got used to it and most of it is hidden and it will stay there.:)
uh looks fine to me , a lot of people hide them behind the rear side pods o nthe monster(as have i, makes it tricky to adjust)
Looks good to me too Steve. It's not obtrusive, you can easily see it to check the level and it's readily accessible to top up the oil or adjust the flow. Nor will it be affected by engine heat reducing the viscosity of the oil. :thumbs:
