Scottoiler - Ducati Specific fitting
Rory@Scottoiler
Hi all,
As mentioned a while ago I've been investigating a Ducati specific install, via the front sprocket cover. I've been putting a kit together over the last couple of weeks, we have a nice new 999 coming in on Friday so I'll be able to try this install and get pictures to show you what we're thinking of.
Watch this space...
:thumbs:
retro fit
Rory@Scottoiler said:
Hi all,
Watch this space...
:thumbs:
hey rory give me a free one and ill try retro fitting it to my existing one on my st2 just to see if it could be used for other models............obviously im only offering out of the goodness of my heart ;) :comp2:
I can test them as well just to see if it'll fit a multistrada Rory :D
Emailed you on your hotmail account.
Not compatible with 1000 DS engined bikes :(
It's based entirely around the sprocket cover which is standard to so many models.
Fraser Scott (our founding {grand}father) has a MS 1000DS so we might come up with something for that too....:confused:
I've got a 999 I use for touring as well :)
Well I shall get something to you, will you be in Fort William for the MTB World Cup? I'll be doing a presentation to the competitors doing the Wilderness Arc Adventure race, which is happening in the area at the same time.
So I'll be there, was there last year too, having a nosey at the new P7 avec funny dropouts... ;)
Update
Had an 06 999 in today, have completed the install and have evolved the front sprocket kit a bit.
I'll post pictures here on Monday showing the setup, very neat, even if I do say so myself :thumbs:
:beer:
I hope this is not too off topic. As far as I can tell, the only reason some folks decide not to have a Scottoiler is because they reckon it looks ugly...well I think mine looks the mutt's if I do say so myself :thumbs: And...no problems so far being so close to the pipe :p
I should be there, haven't booked me hotel yet though :(
The new P7 is going well, too well, sold out until Mid May amazing what adding those dropouts has done to it, got a lot going out singlespeed.
You hardly notice its there eonan
Rory
I put a scott oiler on my 749s a couple of weeks ago, Put the application on the front sprocket. it appears that only the outbord part of the chain is oiled, Is this correct.
Mark
mark749s said:
Rory
Mark
yes and no...
The oil is only delivered to one side of the chain, but if fed down the sprocket face as recommended then it enters the chain on the inside face of the outer plates. It then works its way across the chain (both on the roller and across the pin) by capillary action.
We recommend you load the chain up with oil from the bottle in the first instance as this makes it easier for the new oil added to travel across the chain.
A good example of this working is a tuned 167Hp Blackbird chain we have which is within its wear limits and was only ever fed oil from a single sided dispenser.
:thumbs:
Hi Eonan,
Totally agree that people are put off by the possibly ugly install. It can be done very neatly in most instances.
Our new front sprocket feed is a lot neater in that you dont need to glue / cable tie the dispenser along the Swingarm, plus on certain single sided swingarms such as the S4R Monster it's just not an easy install to the rear sprocket.
As for your install, looks nice and neat,
But...
The Scottoiler system is a gravity feed, the reservoir itself merely being a valve which opens when the engine is turned on. While this valve is open the oil is allowed to drip down the delivery tubing to the front / rear sprocvket.
My concern with your set-up is the total lack of gravity head. We recommend the RMV (reservoir) be positioned about 30cm above the dispenser nib. I imagine you have the flow turned up quite high? Practically on prime?
Also due to the proximity to the exhaust you might need to use our High Temperature (Red) oil which is thicker than our traditional (blue) oil.
Hope this is useful information :thumbs:
I'll be booking space for a tent by the looks of it :(
:thumbs:
Hi Eonan,
But...
Thanks...that really is helpful. Will the new front sprocket feeder be available soon? If so I'll just upgrade to that instead of moving this one.
Hi Eonan,
The M750 doesn't use the same front sprocket cover as say the 916, 996, 999 etc so the kit I'm developing wouldn't suit it. Have you got some more pictures of the front sprocket area of the bike? If so could you email them to me at rory@Scottoiler.com please so I can have a think about this one. It looks like it would be possible to feed via the front sprocket quite easily going by the picture you posted. However the RMV would need to be raised to give a gravity head over the front sprocket.
Thanks, Rory
Sorry for the delay folks been hard at it.
I received the sprocket cover drilling templates from the printers today, so am getting some sample kits made up for some feedback from testers.
I didn't get around to posting pictures of the install, but the pictures below show the set-up on a 999 we had in a good few weeks ago.
The top picture shows the front sprocket feed, note that red oil (High Temperature oil) has been used due to the proximity to the engine.
the next image shows where the RMV (Reservoir Metering Valve) was positioned on the frame, hidden behind the side fairing.
and the final image shows how the RMV sits relative to the side fairing.
:thumbs:
looks good Rory, you got a photo of the inside of the cover so i can see how the nozzle goes through
Cheers, it's got to look good, I appreciate that...
I'll post a pic of the nib itself tomorrow when I'm back in the office, can go one better and post a picture showing a clear mock-up sprocket cover to let you see what's happening behind the cover.
Those clear sprocket cover pictures as promised, note that the clear cover was just a mock-up for us to monitor where the oil was feeding and how durable the nib is.
The nib is made up of a piece of silicone rubber tube which is highly flexible, inside which a more rigid piece of PVC microbore tubing with a slash cut end is housed, the slash cut rubs on the face of the sprocket and the silicone allows for any flex / movement (e.g. wheeling the bike backwards)
There are 3 nibs in the kit in case you need to replace it, they will be available for pennies as spares too.
[qimg]http://i5.photobucket.com/albums/y190/rory182/Ducati/AUT27617.jpg[/qimg]
[qimg]http://i5.photobucket.com/albums/y190/rory182/Ducati/clearcover.jpg[/qimg]
rory ive got the twin feed on mine will this be as good at oiling the chain as that ?
Gord,
This wont feed oil to the far side of the chain like the Dual Injector, its more comparable to the standard single sided feed achieved with the Universal kit alone.
If the front sprocket happens to have through holes in it though, then these act as transfer holes and carry the oil across the sprocket to feed oil on both sides as per the Dual Injector.
So it really depends on the sprocket you're using...
Dropped a few kits off with Ducati Glasgow this afternoon, hopefully they'll have some positive feedback soon.
Cheers, Rory
Gord,
Cheers, Rory
ill let you know how i get on dont think ill get it donr for a day or two but as soon as its working ill tell you
cheers mate
here is mine at long last.
I bought the billet aluminium sprocket cover off ebay for £15 at least you can see where the pipe is positioned and clip it on
Mark
Mark,
Looks neat, where are you feeding the oil?
say you're looking at the sprocket side on at what 'time' are you feeding? e.g. I recommend between 1 & 2 o'clock on the front sprocket and between 5 & 6 o'clock on the rear sprocket.
This is basically to achieve fling into the chain whilst the oil also runs down the sprocket face.
Looks good though, the RMV is the same as we've done on the 749 & 999.
Cheers, Rory
