S2R 800 dash problem
Martin Duke
Help! My bike was without a battery for a week and since then the odometer has decided to display -----miles instead of the 7240 the bike has covered. The trip works and can be reset, the clock, oil temp, speedo, tachometer and all indicator lamps work as normal. When I re-fitted the battery the bike started as usual - I let it warm up and then put it into the garage. Next morning it started OK, but kept cutting out if the cold start lever was closed - I started to ride off the drive and it cut out again, pressed the start button - nothing! I lifted the tank and checked each fuse (all OK) - connected another battery via jump leads - still nothing! Then the penny drops, it's still in gear!
Into neutral, starts OK but isn't running too well, cutting out every time the throttle is closed. Within a few miles it is back running well and I cover about 130 miles during the day, with several breaks - it starts instantly, runs smoothly but doesn't display its mileage. Could I have reset something by removing fuses? Any ideas? :confused:
Now fixed!!
A phone call to Mark at Scorpio Electronics (Google for details) and the instrument cluster was removed and posted to him - it seems as if the memory had been corrupted somehow, but he was able to retrieve the actual mileage and everything now works as it should - hurrah!
A decent turnaround time and a fair price too; usual disclaimer - I have no connection other than being a satisfied customer.
