Running on one
CST
First off Hello to everyone, I am a new Ducati owner in need of some help, I bought my self a long sought after Ducati two weeks ago, 2001 ST4S, barring the ride home have not had a chance to use it…..
I stay just north of Aberdeen and picked the bike up from Edinburgh on the 15th of Feb all was going well nice dry day little cold but not bad for mid-February. Bike was running nicely until Dundee, then dropped to one cylinder not having breakdown cover I continued up the road intermediately it would pick up to two made for an interesting ride especially when it decided to do this half way round a roundabout.
Anyway back home pulled the fairing off checked the exhaust manifolds the horizontal cylinder was not firing. Pulled the plug and discovered no spark (plug was also wet if pulled straight away so have fuel). Checked voltage to the coil plug is fine, is shared with the other coil and injectors (brown and white wire) so that is there as a further test I switched the relays about still nothing, pulled the plugs from the ECU and belled the negative coil pulse wire (blue and grey) back to the ECU all good. Did notice the ECU plugs have been re-spliced for some reason but pulled the self-amalgamating tape off and checked the splices seem good. I swapped coil/ lead and plug between cylinders but still no spark on the horizontal cylinder. Decided as a matter of course to replace plugs coils and leads (OEM coils, 8.5mm Magnecor leads and iridium NGK’s gapped to 40 thou) still nowt though! Have gone round the bike checked plugs connectors relays and fuses including the large front loom to main loom plug (removed the rubber boot looks as good as new).
Bought myself the Fiat lead and downloaded DucatiDiag, plugged in I am getting spurious faults on the ECU, every sensor is reading as Short circuit to ground however bike still starts easily and runs on the single cylinder quite happily (this rules out stand switch, immobiliser and kill switch). To me it looks like it is a dodgy ECU appears to be the original IAW 5.9 ECU (part number IAW59m.A3).
Does anyone have any other suggestions before I shell out on a replacement ECU?
Looking at my options I am contemplating the slightly expensive Microtec replacement- I intend using the bike to commute and need reliability even if my ECU could be repaired (if it is dodgy) I don’t think I could trust it.
Any help or advice greatly received
Coils can break down under load while giving an OK resistance reading with the ohm meter. Have you cleaned out the HT socket?
You've done all the tests I would have done including swapping the coils and leads between cylinders which more or less rules out the coil leaving only the ECU. The coil drivers in the early IAW5.9M ECUs have been known to fail. The same ECU in Fiat cars (different firmware) also fail in this way.
To test it for definite;
Fit up a indicator or brake light bulb (21W) with a pair of flying leads, preferably with clips on the end.
Connect one lead to the battery +ve and the other to the horizontal coil -ve wire (Pink/Yellow going to ECU).
Turn on the ignition and crank the motor.
The bulb should pulse on/off as the motor turns, in which case the coil is faulty, if not the ECU is duff.
If it is there are a few firms doing ECU repairs that may be able to help :-
http://www.ecuclinic.com/
http://www.avantiraceparts.co.uk/page.php?id=19
http://www.motomatrix.co.uk/ecu-repairs.html
Getting the ECU repaired will typically cost around £200 but IAW59M ECUs are harder to find used and are more usually expensive than the later IAW5AM. Also you won't have the hassle of dealing with the immobiliser issue. Changing the ECU could also require changing the immobiliser and keys as they are all linked, which could turn out very expensive. But a replacement ECU can be "virginised" so that it will work with any black key until the red key is used, then it becomes linked to that key, or the ECU can be re-flashed to disable the immobiliser function.
Hope that helps.
thanks Serious Black, I have replaced the coils with new and swapped them between cylinders still horizontal is missing spark though.
have also gone around and cleaned all the connectors.
thanks
Hi Derek,
thanks for the conformation, I forgot to add I also tried the bulb check to no avail,
I tried getting hold of Avanti Race Parts last week not answering the phone, will try them again.
if the ECU is repaired I take it I would have to reset the TPS and CO, I see the DucatiDiag can do this but is it quite an easy task?
thanks again
The TPS is a mechanical reset on the ST4s so it would probably be ok but the fuel trim values are stored in the ECU so It is possible that these might need resetting after a repair. I'd try it and see.
The procedure for setting the TPS and CO is documented here : http://www.bikeboy.org/ducati4vthrottleb.html
  • Like
Reactions: CST
You say the plugs for the coils have been spliced at some point. Have they been spliced the wrong way round? This would reduce the energy available at the spark plug by about 40%. Out of desperation, I'd be having a shufty at the injectors too.
The loom at the ECU has been spliced this is the Blue/Grey -ve signal wire only, I have belled this from the ECU connector back to the two point coil plug, checked the continuity and for shorts with other signal wires at the same time (this was my initial thought). the Brown and White +ve (shared with injectors and vertical coil) is fed from the under seat relay, have swapped relays and confirmed the voltage is there and not dropping when starting etc, know there can be issue with starters pulling voltages down.
the cylinder (in fact both cylinders) are definitely getting fuel, spark is the issue, with bike running and plug out you can see the fuel vapor from the plug hole, yet no spark.
going to try and get the ECU checked and if necessary repaired.
cheers
Quick update for anyone who may be interested, I spoke to the three suggested ECU repairers although they list IAW 5.9 ECUs, two out of three said was not possible. Finally got Avanti race parts and they are able provide me a replacement with the correct map and a years guarantee for £399, they said they could potentially repair for £299 but this takes time and I am impatient plus there is no guarantee it could be repaired so could end up replacing anyway.
Hopefully this will arrive before the weekend and I will get up and running soon although maybe not this weekend with the forecast!
Hello again, good news bike is fixed ecu fitted and running on two. Fight to get the fairing back on but otherwise an easy enough job. Thanks for advice and help now hopefully the fun can begin.
