wulfie
Sooooo having put the bike in the living room sprayed up all the parts over the festive season I had the carbs off and put a stage 3 sigma jet kit in the carbs and put everything back togeather started the bike with no issues! she was running sweet untill put the bike outside to go for a run and now im only running on one cylinder the vertical one to be exact the front is not firing.
I took the plug out it had fuel on it but not enough to flood it or stop it from fireing cleaned it up burled the bike over with the plug to the cylinder head and I had no spark at all I bought a new set of plugs and a coil which I just fitted and i am still running on one.
Tired fireing up the bike a few more times to no luck although I did see this wire coming from my casing smoking like hell so ive just stopped before i end up burning the bloody thing to the ground.
There was heatshrink over the connectors but they melted off.
View attachment 12264View attachment 12265
help im at a loss and getting @@@@ed with the thing after doing everthing to it over winter
