Rubbing brake line
stevie749R
While cleaning the bike earlier spotted a whole area on the fork body where the brakeline has rubbed through the gold coating to the metal underneath. Obviously this is due to suspension movement but surely it shouldn't be happening. Is this a common problem or something I should be concerned about? any help/advice welcome.
it is quite common you need to try and adjust the line so it doesn't catch but it isn't always possible without altering the hose guides :(
If you can't adjust the lie of the line to clear the fork leg you could fit some spiral wrap plastic around it where it is touching.
Hard to explain without a photo, get some rubber hose about 1-2cm and run a cable tie through it, loop it around the brake line back through the hose then around the fork leg and pull tight.
The hose acts as a spacer and moves the brake line 1-2cm away from the fork leg, do this on the race bike
I think that explains it quite well without a photo! ;)
Stevie,
I've had this on my 748R. Are you sure it's the brake line that's rubbed through the fork and not the speedo cable????
Mine's was caused by incorrect routing of the speedo cable to the sender on the LHS front wheel spindle. If it is your speedo cable it should be routed in between the two caliper bolts and not above the top caliper bolt.
If it is routed above the caliper bolts it 'fouls' on the fork leg as the suspension travels and cuts a groove in your leg as I found out much to my annoyance (twas routed that way from new until JHP found it).
Guy
