Replacement aftermarket mirrors for 999
Doctor Love
Guys looking for a bit of advice on this one.
After my bike falling on its side at the masher, I have now purchased a pair of aftermarket mirrors for my 999R got them on the internet, they look similar to Franks - they are black and on 1 stock, long enough to be able to use without lifting my arm up to see what's behind me.
The question I have is this,...they have a LED strip for the indicator and what is happening when I activate the indicator - is its now flashing faster that what it should.
I think that the problem is that the back indicators are working from normal bulbs,...which is causing the problem.
How can I fix this???
Thanks guys:thumbs:
DL
David,
You need a ballast resistor wired in parallel with each front indicator so that it draws the same current as if it were a bulb. Here is one on eBay.
David,
Derek, how do I fix them on to the bike? is it an easy fix?
I don't want to start cutting into looms ECT
Thanks
DL
Hi David,
Just a query , have you had the bike running and then turned the indicators on ?
If they still flash too fast as Derek said you'll need a ballast resistor I'm afraid
David,
Should be no need to cut into the loom. It would be best if you could fit them inside the indicators but I suspect that there is no access. Find the 2 wires from the indicators where they plug into the bike's harness and either uses Scotchlok IDC connectors to piggy back them into the indicator wires (not my favourite way of making a connection but quick and easy) or bare back the insulation, solder the connections and use self-amagamating tape to cover the join. You could make a better job by using male and female bullets to enable the resistor to connect in-line between the loom and the indicators but it's a bit hard to describe.
If I have time later I can try to make a drawing for you.
Here's the drawing I promised. Don't know if it makes if any clearer though ;) :).
The wires from the loom to the indicators are green/white and black on one side, and green/black and black on the other side (according to the wiring diagram :rolleyes:)
