Renthal chain finder
It lists the ST4/ST4s as 1999 - 2001. The ST4s didn't appear until 2002 and it gives the chain length as 120 links when it should be 102. It lists the OEM rear sprocket as 43 tooth when in fact it is 38t. The MTS1200 isn't even listed. It's rubbish Frank!:D
Even worse it seems the factory manual is also wrong and standard sprocket bikes came with chains with 100 links.
