Removing oil breather
Gizmo
Forum Geek
Trying to replace the plastic oil breather but cant work out what size spanner is needed, cant get adjustable in or get grips on it :doh:
Anyone have any idea of what i need or an easy way to do it please? TIA
problem solved, for anyone interested i got it off using one of those thin adjustable band oil filter tools, a chain one wont fit between valve and cooling fins so I adapted a metal strap one, it just fit into gap, need a couple of small plastic blocks to get it to tighten and once on valve loosened easily. new one has holes into which you can insert ball ended allen key which makes the refit a lot easier.
