Removing Datatool System 3
Gizmo
Forum Geek
Linzi's bike decided not to start when we fuelled up at loch Awe today, worked out it was the alarm and after a call to Scottch who kindly downloaded the datatool instructions we got it running again. Fookin annoying when its an add on bit that isn't much use anyway
Her bike came with it fitted but TBH we don't need it as there is no insurance requirement so we were thinkig about removing it. Has anyone had a datatool removed before? how easy/hard is it to do?
I removed the metasystem 3 from the 996, took 2 or 3 hours and had to replace several lengths of cable from the wiring loom but all in all very worthwhile.
Its an easy enough job to do, had to remove a system 3 of the DD bike when I bought it. Get some heat shrink tubing to reinsulate where you have to rejoin wires and your away.
If you can ride it down to mine I will have a go, shouldnt take more than an hour to do a proper job. Failing that give me a ring if you get stuck.
A friend who operates guided tours in Europe said that about 70% of breakdowns are down to dodgy alarms, either poorly fitted, or as a qualified Datatool fitter said to me, even if they're fitted well, after a couple of years the springs/contacts in the various relays/solenoids begin to wear and cause intermittent faults.
A completely un approved option if you have to have an alarm for insurance purposes is have the motion sensor working, and or even the starter relay immobilisor part of the alarm, but do not have the second (more crucial) part of the immobilisation circuit that is usually wired into the ignition circuit or the fuel pump actually wired in, therefore preventing mysterious misfires/cutting out etc.
The source of this suggestion is not me, its someone well connected with alarm companys, but does not want to be named as he has seen it all many times before.
