Looking for a rear paddock stand for my soon to be acquired 1000ds - none in Duc. Leeds - all on back order. Is there an alternative to a 'Ducati' made stand - they run out at about £130 which is quite exp.
Any stand that fits the 916-998 etc will do. Theres Micron, Harris and load of others. Try having a look on Demon tweaks and suchlike. Worth checking ebay as well. Try and get one that has a bearing as you can have problems with the bike working its way off the stand when youre cleaning the chain etc.
I can highly recommend the Abba stand but by the time you've bought it with the necessary adaptors to fit the bike it won't be much cheaper then the "Ducati" one. The Abba stand fit sinto the swinging arm pivot and lifts the bike like a centre stand would, leaving the rear suspension unloaded and by putting a jack or a block under the engine you can get the front wheel off the ground too.
How much is it for a centrestand ? Mine already had one when I bought it second-hand form Ducati Leeds. I would rather put that sort of money towards a centrestand.
