Rear shock removal
iconic944ss
Just in case its of use....
"Found a local service resource near me so finally decided to get my 15 year old Ohlins rear shock overhauled at long last.A few things the manual never mentions...
The front footrests need to come off, the side panels too really to prevent damage.
8mm hex bits will be needed to remove the shock unit itself, top one is VERY tight and the bottom one is accessed via a plug in the swing arm and the bit needs to be at least 50mm long to reach the bolt head. I eased the preload adjuster out first, then brought the bottom of the shock out via the left hand side of the frame, while easing the Nitrogen reservoir between the seat frame tubes!
Any helpers for re-installation - very welcome. Cheers"
Your lucky you don't have an ABS model. Getting the reservoir past the ABS unit is almost impossible :mad:
To furb or not to furb, cash is the question....
Tidy up time now that the shock is away for overhaul, ride hight adjuster is all good BUT, there has always been some vertical play when checking the swingarm. Sadly, I think Ive traced this to play in the rocker arm assembly (its in all directions) - not much, but very much there.
Parts file, makes it look like FOUR needle bearings and a pair of seals and I just KNOW, if it try to inspect that at least one of the bearings is bound to fall to pieces on me.
Think I'll see how much the shock overhaul costs before making a decision.
Frank, the rocker pivot bolt needs to be tight, very tight to 75 Nm. Not easy access to get a torque wrench on. The sleeve that the bearings run on gets clamped between the frame sections. If it's not tight enough the sleeve moves creating play at the rear wheel which is amplified by the suspension linkage. Worth checking.
