rear seat unit
hoggy
Please can anyone help ! I have a 400ss and want to fit a nicer seat unit, as the original seat is damaged. Can anyone recommend a good replacement, want something like a 851 look but not sur eif thats possible.
Cant help with the single seat but I do have a dual seat pad that I took from my 600ss before selling it. Good condition think there may be a small 1/2"" tear towards the front corner. can email pics if you wish
PM me if your interested
Anything is possible provided your a bit handy on the diy skills and are not afraid to cut plastics etc.
I've just finished fitting a 998 race seat unit to an 800SS, it's well fixed and looks fine, but I had to make brackets to suit and fix with Dzus fastners etc + cutting the seat around the fuel tank shape etc.
If your looking to do it on a road bike you've got the added complication of the lights as well which will need a bit of thought on your part.
Have a clear idea what you want to achieve
Consider how the seat mountings for th enew seat compare to your bracket points and how to make both match
Once matched how do you fix? Dzus would probably be the easiest
look at the seat height at the tank end, SS seats are mounted quite highly up the tank so be careful about matching final seat heights otherwise the ergonomics / riding position may end up being out.
Dont be afraid to cut things to make it work
only take it on if you have a garage and tools etc as it will always take longer to set up right than you planned for. ;)
seat unit
Many thanks for the sugestions.I had not thought about the lights yet or tank height issues.I,m not bothered about ride height as I want a racy look and its only being used for local sunday runs. I wanted to keep it standard at first but that idea is going rapidly out of window due to other issues, the bike is developing,,,, many thanks again.
