Rear LED Brake/tail light conversion
ian900ss
For those that may be considering it, I include pics of todays tinkering with the rear stop tail conversion.
I started with a stripboard, cut and shaped to fit the rear lens, painted black on the front.
I started from the outside in raising the LEDs on each said to match the contour of the lens
Did them in banks of four (4 LEDs in parallel and resistors to drop voltage)
Testing
Tail just 7 in the middle
Brake all the rest round the edge
All together
Hot glue to stabalise the LEDs
Then into the lens
There you go, just got to work out how to mount it all and I have to install white LEDs for the number plate, which are on order. Next the indicators. I was inspired to do this by Derek, who changed all the lights on his ST I now own.
I found out the hard way that hot glue was absolutely essential. Without it all the LEDs rattled themselves loose! :comp2:
