Rear brake return spring help required.
Yorkie
Help needed:
Is there any way to fit the rear brake return spring on a 916 without snapping the spring, maiming a digit or taking an eye out.
Do the return springs from a 748/916 differ from the later ones as I cannot see a logical way that it should fit?
I have already broken one and at £5+ it could be an expensive habit.
Cheers in advance,
Yorkie
Sorry can't help. The same part number is used throughout and was the same on my ST4s which I certainly had off but I can't remember having any difficulty with it.
