The 900ie has an open loop system and won't make any adjustments for airflow changes at all. At any throttle opening it will inject a predetermined amount of fuel dependant on air temperature, air pressure, engine temperature and rpm.
Either get a DP chip, or fit a Power Commander with the correct map for that engine/exhaust/air filter combination or better still get it set up on a dyno.
