Rattle maybe valve issue on 748
bushboy
Hello all,
Quick question.
Got a 748 2001 mdl, not had it long. Full svc history blah blah. ( 6500 Miles )
I notice that at approx 5000 rpm the top end sounds a little rattly, like excess valve noise. Not there at full throttle nor at idle just in the middle few thousand RPM's, other than that all OK. Not had a duke before so hence question.
Ideas? is this normal. Will take to local dealer? again who is best, in Manchester ( M43 ) and dont mind going the distance as long as workmanship OK. Not to mention cost.
Just thought worth asking you lot. Never know!!
Bushboy.
Well you've got a few options locally, Duc Manchester near Lymm, Cheshire although I wouldn't... Italsport in Bury... never used them but they are on the board so maybe able to help.
Many praise Ducati Leeds and charlie is registered here also, and I believe there a good bunch. Personally I take mine down to JHP/Ducati Coventry simply because Johnny Hackett has built engines for the likes of Bayliss, Hodgson, Hizzy etc and prepares all of Ducati UK's press fleet... so that says something.
Might be worth a call just to see what they say
The noise from the bike should change throught the rev range, at 5k on the 748 you will be getting the air induction starting to kick in. I changed to carbon air tubes and I get a buzzing sound at about 5k.
To be on the safe side take it for a once over. Ducati John also recommended in Leeds (Ex BSB) http://www.ducati-john.co.uk/
