HootOwl
Well-known member
I was putting this together for work anyway, but some of you may also find it useful, especially if you are a Multistrada rider which can tend to cook the rear brake fluid due to the proximity of the cat.
Care always has to be taken not to mix any DOT 5 fluids with any other grades. DOT 5 is a different type of fluid to the others (its silicone based).
DOT 3,4 and 5.1 can safely mix though its better to stick to the same grade.
There are differences in pricing too. The SRF looks extremely expensive, but comes in litre bottles, not half or 250ml like some of the others.
What's Wet point and Dry point temps you ask?
Well dry point boiling point is that of fresh, clean brake fluid straight from a new can
Wet point boiling is what happens when the fluid as absorbed around 3% water content from the atmosphere. ( DOT 3,4 and 5.1 brake fluid is hygroscopic), which takes between 1 and 2 years usually, that's why you should always change brake fluids every two years max.
| Dry Boiling Point C | Wet Boiling Point C | Dry Pos placing | Wet Pos placing | total | Average rating | |
| Castrol SRF | 320 | 270 | 3 | 1 | 4 | 1 |
| Ferodo FRF Racing | 339 | 199 | 1 | 4 | 5 | 1 |
| Motul 700 Racing | 336 | 205 | 2 | 2 | 4 | 1 |
| Motul 660 Racing | 325 | 205 | 4 | 2 | 6 | 4 |
| Motorex Racing | 300 | 195 | 5 | 5 | 10 | 5 |
