Just as an update for anybody else that's thinking of doing it.
The job took a long time, but I probably *arted about quite a bit, not really sure what I was doing. At one point with everything reassembled I noticed that the pressure plate was not moving out evenly across the face. This used to be a problem with the clutches with the old Bevels. Biggest single improvement from my old Darmah to the 'new' SS to me was the quality of the gearchange,- the newer bike is featherlight in comparison.
I quickly sorted that though.:comp2::banghead:
I spent time filing off the ragged edges on the old plates I was using & also the slight burring on the clutch basket.
After completing the job the gearchange was clunky & the clutch was dragging, & it didn't want to come out of gear back to neutral without a struggle. I was going for a run the following day, & was hopeful it would improve with some miles on it, & that's exactly what happened. After 70 miles or so the change mechanism seemed as good as ever on the move, still a little tricky at very low speed, but improving.
Some noise can still be heard, but if I've lengthened the clutch life by stopping it from clattering itself to bits I'm happy. :thumbs:
