Quick release petrol fittings - 999s
  • Thread starter Thread starter alane
  • Start date Start date
A
alane
Just visiting
Whats the score with these?
Being more used to jubilee clips and stainless braided stuff I've never had to remove a qd pipe connector before.
Do I twist, push, pull, squeeze, blow, heat it up, cool it down or what?
Thanks
sorry I know its scorchio out there but please spare a thought for those of us who need to wait for good weather before attempting outside maintenance.
all I can hear is bikes go past the end road...bugger!
Neccessity is the mother of invention!
QD clips are released by squeezing the ring nearst to the tank 'falnge' right at the top of the connection. Hard to see or reach until you pull the tank out of it's front retainers and raise the back end reet up.
Next question - how do you remove the clips from the ends of the fuel filter? are they replaceable items each time the filter is changed?
Cheers KDB.
I guess I didn't have small enough pliers so opted for getting a new pair of clips for £4 from DM.
Cos I managed that I went on to do the air filter as well (time was flying) but therein lay a problem....one of the screw stud things snapped off just above the thread and had to drill/heat/melt/remove/install/wellnut...and in the last hour it started pee-ing it down.
I must have been wicked at some stage to deserve this but I can't remember when.
Must say, I find it pretty crap that when the bike was last servied they didn't smear copper grease on the steel>brass fittings on the plenum (air box).
Each screw was pretty tight and it was penny to a pound that one of them would snap.
Quick release plastic fitting - you have to squeeze the very topmost ring:
Fuel clips, old and new
9,000miles of crud in the air intake tube. For thos who don't think it's worth cleaning the air intake and filter every now and then:
The new well nut and the captive brass thing that goes in the plenum (mit stud still broken in it)
