Hi there Wulfie, I've fitted 1098 Ohlins to my 748, the 916/748 top yokes are reused but you need the 56mm ohlins bottom yoke then they will physically fit the bike. There are a few issues though, you will lose your speedo drive as the 1098/848 use an electronic pick-up off the rear wheel(as do 749/999). The 916\748 wheel will be off-centre if you use the 916 speedo drive as it is too wide, it didn't matter to me as I'm using a Marelli dash so I used a 749 pick up sensing the front disc bolts (I had to swap my nice titanium items back to steel on one disc though - the sensor only works of a ferrous fastener
) and I had a spacer made up instead of the drive unit. The brake calipers are also more offset than the std 916 items as well so you will either have to use spacers to offset the std 916 discs or do what I did and use a set of 996R discs which have the larger 15mm offset and fit perfectly. In summary as well as the forks you will need: two 100mm radial calipers, a 1098 wheel spindle, two spacers (one is the std 1098 small spacer and the other will have to be custom made - I can't remember the exact length just now but 27mm rings a bell) a set of disc spacers (or 996R discs) and the 1098 mudguard.
The easy but expensive way around the speedo drive issue is to use an aftermarket dashboard but perhaps the 916 drive unit can be machined down?? If you need any more info just ping me an email and I'll do my best to help bud. I can also send you a load of pictures of the various bit's and pieces I used if you want as well, the one below is during the trial fit phase but I am now finished the front end completely so pics are no probs.
[qimg]http://i439.photobucket.com/albums/qq111/chrisair1/DSC04701.jpg[/qimg]
