Question for carby SS owners
Pict
Look at the cross strut where the top of the shock attaches. To the right of the hole where the tank 'prop stand' goes there is what you might call a 'pip' or less charitably a blob of weld.
On my first SL I thought thats exactly what it was, but now on my 3rd and they all have it.
Why is it there?
:confused:
I know the blob ur on about,my current SS doesn't have it but this bike was re framed in 2000(DUK supplied the frame)
Hi not got an SS but from a welders view and what you describe it may be a expansion hole which allows hot air to escape. On short pieces of tube when welding the air expands and can blow out in the weld pool if it has nowhere to escape giving you a fecker of a job trying to fill as this usually happens at an awkward position. Once welded and cooled you can just give a quick spot weld to seal the tube.
Hi Sam, good call, but it's on a flat, not a tube. I will take a picture before I grind it off :)
