Project Ohlins MH900e
RWG
Hi To All,
Who may be interested in project Ohlins, I acquired a set of Ohlins front forks from a 2002 Aprilia RSV mille R,
All sounded good and measurements seem to match 65mm ctr for calipers and fork diameters seem good. Stripped bikes front end down just removing cockpit fairing, striped forks and tried to fit Ohlins legs. That is when I found the only discrepancy, that being the section that fits in to lower clamp is 2mm bigger (56mm)rather than 54mm, all else looks good to go.
Question,
Does anyone know if any other lower clamp would be a suitable replacement as I do not want to alter original, help much appreciated.
Regards
Paul
RWG
I fitted 748R Ohlins to a 900ss, and in the end had the lower yoke bored out to fit them as there wasn't one that would bolt straight on. It might be worth getting a spare yoke to do this. If the MH900e's front suspension is the same as an inj. SS it should be reasonably easy to get a hold of one.
Aprilia Ohlins forks, St2 lower yolk and should be further along the way, will let you know.
