torque setting of the front Aaxle is 70 to 76 Nm, front axle pinch bolt torque is 20 to 25Nm.
Clutch judder could be a few things - worn or warped clutch plates being the most likely could also be clutch fluid needing Changed / Bled , do the fluid checks first its cheapest
Spitting back through the intake sounds like ingnition too far advanced or poorly seating inlet valves
