Problem with ducati anti-theft kit
ray wynn
Hi all, i have a ducati anti-theft kit fitted to my hypermotard but i cant get it to switch off, ie. Cant use bike. I have disconnected the battery and checked the voltage { 12.75 }, reconnected it and still no joy. The battery in the fob is ok and i have traced all the wires and everything looks ok. The light on the fitting that comes with the kit is coming on , but nothing is happening. Help !!!!
Sorry Ray, can't help you. It's possible that the alarm has got spiked and needs a reset or maybe the internal battery is knackered. If it's Ducati alarm you should call Ducati Glasgow. If it's a 3rd party alarm you should contact the manufacturer.
If you were a bit nearer to me I could remove the alarm, get your bike working again and chuck the alarm in the bin. Best place for them.
Attached is the instructions for de-spiking a Datatool System 3 if it's any help.
Hi Ray, there is a guy out at Dochgarroch that works with Loch Ness Restorations ( a motorcycle restoration & service garage). He is an electrical guru for all bikes of all ages, I know of a couple that he has sorted out alarms on, look up their facebook page, guys name is Graham. I know they are snowed under with work but you never know.
sorry ray, can't help you. It's possible that the alarm has got spiked and needs a reset or maybe the internal battery is knackered. If it's ducati alarm you should call ducati glasgow. If it's a 3rd party alarm you should contact the manufacturer.
If you were a bit nearer to me i could remove the alarm, get your bike working again and chuck the alarm in the bin. Best place for them.
Attached is the instructions for de-spiking a datatool system 3 if it's any help.
hi derek, its a sealed unit so i cant reset it. I will let you know once d/g get back to me. Thanks ray.
hi ray, there is a guy out at dochgarroch that works with loch ness restorations ( a motorcycle restoration & service garage). He is an electrical guru for all bikes of all ages, i know of a couple that he has sorted out alarms on, look up their facebook page, guys name is graham. I know they are snowed under with work but you never know.
hi there, just waiting on d/g getting back to me. If its nackered i can ask a motorcycle mechanic to strip it out. Thanks ray.
