Problem Getting Bolts to Screw In
eonan
I’m having a bloody nightmare trying to fit the swing arm pinch bolts (I’m using the original bolts). I’m getting the bolts to screw in to about half way, beyond that they won’t budge :comp2:
The threads look clear enough, well, at least there’s no paint down there anyway. I've poured down release agent and degreaser etc, but still no joy.
Any ideas what might be causing the problem, or what to try next?
Any luck with this - I see you posted it about an hour ago. I can't understand why they won't go in. Did you have the swinger blasted before it was painted? if it was there may be some cac left in the threads, it may not be that visible - got a tap? run it through to clear it out. :)
Happy Christmas - by the way! :)
Sounds like the guy who did the powder coating did'nt mask the threads.
Try running a tap down the threads to clean them up.
Good luck. Ranald.
Happy Christmas Edward :santagrin:
Yeh they may have been blasted...there does seem to be something in there right enough. Ah well, time to add a tap set to my tool box :rolleyes: :D
Could come in handy. As Rikki Fulton said...."you know the answer for water on the brain? .............................. a tap on the heid!"
Are you sure they are the original bolts?
Sometimes fine pitched ones are used. With the wrong pitch you can get a few turns in before they lock up.
Definately the same, unless some muther f*cker has been messin' with the lables on my little plastic bags :mad: :D
I'm managing more than a few turns....they're going to about two thirds so I'm pretty sure they're the right bolts.
