Potential fault from tank prop
iconic944ss
My saga with fuel lines continues but thats not the focus of this post.
While trying to see where fuel lines were going, I decided it would be easier (since my tank was still off for fuel filter changing) to remove the tank prop rod...
Directly underneath the boss for the rod end is a connector block that on my bike has had the sleeve rubbed & broken open by the end of the prop rod. Quite a few zip ties in place on my bike so perhaps, this might not happen on a standard bike but worth a check.
Will post a piccy when I get chance.
Trying to figure out which connector block Frank, it needs that pic. From what I can picture it is either the connector for the CPS or the ignition switch.
Will do Derek, cheers, wondered what it was myself - only seems to have 2 or 3 wires without close inspection.
Not been to bed off nights yet, so will snap a pic tomorrow.
Not brilliant photo's as it was dark outside already by the time I got around to taking them...
Looks like a brown and a white cable but I need to look closer with a spy glass in good light.
Well it's not the ignition switch connector. Its quite a big 6-way connector with 4 fairly hefty R/W, R/Y, Y and Y/W wires. On my bike ,at that position is the connector for the engine/rpm timing sensor. You do not want to loose that as the bike will not run without it. The wire colours aren't shown on the diagram, it is a screened cable with 2 internal conductors but the screen will be separate at the connector so perhaps the internal wires are brown and white as yours appear to be.
Both the coils and the injectors have a brown/white wire as the live feed but none of these should be in that vicinity.
Hi Frank
Just checked mine and same problem as yours sleeve is open so i pulled the connector out from the side of the bike to have a better look and there is a black,white and brown wires and there is bare copper showing on the black wire and a blob of solder which looks as if they are all soldered together before they go into the small loom.
The brown and white looks as if they are soldered together and the bare copper on the black wire being twisted around them ???? Will split this open when i get a chance and have a proper look and repost.
The 6 way connector that Derek mentioned which sits just below was where i have already repaired a fault on the main ignition red wire and also another on the connector that sits beside the right hand fork. And just to add to this we found a further fault on a soldered connection on the ignition wire on the left hand side of the bike under the tank in the middle of the loom that heads to under the seat(so that is another hidden potential fault thay have).why they put a soldered connection in the middle of the loom we dont know as there was no need for it. I thought we had found and cleaned/repaired all connections on the bike until you came up with this hidden one. Thanks Frank
Cheers Gents, glad to of highlighted a problem.
I'm going to have to pull the rhs fairing off anyways to get at the factory crimped banjo clip on the fuel hose to the injector.
I'm hoping no bad damage has been done to the wiring harness, looks like damp cold get in there but after the rain me and Derek saw in Austria, only submersion could cause worse problems...
It's definitely the connector for the rpm sensor. The soldered connection is where a piece of proper wire is soldered to the screen to make the connection to the connector terminal. Make sure the connections are sound and seal it up with self-amalgamating tape. As long as the engine starts and runs it is ok.
Cheers Derek will have a better look tomorrow.
Very date update as I've only got around to sorting this...
Back of one of the connectors has 1-2-3 stamped on it which from the wiring diagram I have appears to run to the Immobilizer Ariel? (Item 02 and 06)
The White and Brown cables and indeed sheathed with screened cable BUT the bare screen near the connector then had a Black outer that also went into the connector (NOT as per the wiring diagram). I pared the main sheath back as far as I could to check for bare wires but soon ran out of space.
I'll isolate and repair as best as possible but then its down to crossed fingers, sadly.
The above makes sense to me as I do remember an odd immobilizer problem esp in wet weather - like Austria ;)
