PLUGS again
Works now!:santawink: I'm sure others will know for certain but I would be a bit concerned about claiming to increase the compression due to design.
I can understand the theory on seeing the look of the plug but if it does increase the compression is that a good idea in a road bike? Will the electronics have to be altered to suit? At end of the day the change may be minute but it will be interesting to hear what our resident experts have to say.
They sure as hell will have no effect whatsoever on the compression, at least not that you could measure!
Surface discharge plugs were originally designed for use in outboard motor 2-stroke engines and they are almost impossible to foul but I doubt if they were ever fitted as OEM on any Ducatis
